Diesel leak 2nd gen surf
  • Diesel leak 2nd gen surf
    Any ideas? There seems to be a small amount of diesel leaking near the front right wheel arch.
    It's only a small amount bit want to source where it is before it gets worse, where should I start looking?
    The only time I had a leak it was a seal in the fuel pump. If I remember correctly the fuel lines come in on the Left Hand Side (n/s), so if its on the right hand side (o/s) I'd see if it is dripping onto a strut and running across.
    Gone from 4x4 to 1x2
      Thanks, will have a look :-)
