Hello everybody,
Not been on here for a while. The Surf has been fine, but recent squealing under acceleration turned out to be the three belts, which have been replaced. This noise, now gone, had been hiding a tinny kind of noise, again under acceleration, which I thought could have been exhaust, or from the turbo area. On investigation, it appears to come from the EGR pipe, where it joins the back of the engine. The alloy pipe is covered in black soot. My local garage is going to blank off this pipe bracket with a plate slid in between the joint. My question is, does anything need to be done at the other end of this pipe, or to the rubber pipes which I assume go to various other parts of the inlet end. Sorry for the lengthy blurb, and thanks in advance if any body can help.
