Hi all, got an odd one on her Surf. Driving it on Sunday, as you get to top gear, the revs surge then it goes into O/D. It also seems really flat unless you push quite hard on the throttle, it usually goes much better than this. To get it to downshift I had to floor it too, all f this is around 45-50 mph, takes an age to climb up to 60. ATF is new in Feb, is it likely to be the cable needing adjustment of an ECU on the way out?
It's on 236000 miles now (not KMs)
TIA
TIA
