So, after running around with a cracked head for over a year (thought it may have been just a blown gasket) on my 3l td i've finally gotten around to getting it sorted. My question is what parts is it recommended to change other than the head. I'm replacing the radiator as that had split near the pressure cap, does anything else need replacing.
Replacing cracked head.
Try here http://www.hiluxsurf.co.uk/showthread.php?t=8863Originally posted by Baldrick View PostSo, after running around with a cracked head for over a year (thought it may have been just a blown gasket) on my 3l td i've finally gotten around to getting it sorted. My question is what parts is it recommended to change other than the head. I'm replacing the radiator as that had split near the pressure cap, does anything else need replacing.
Good Luck
14+ Years of Surfs .... n Faultless to a "T" is my Yota !! So I got another ....Buncefield Burner
I had already got a head on the way (http://www.ebay.co.uk/itm/2819137352...%3AMEBIDX%3AIT) i'm hoping as it's a new one and not a refurbished and a unipart one it should be ok, sort of worried though because of how cheap it is compared to rough trax.
I'm in the process of fitting a new head and the carbon build up in the manifold was terrible I had to burn it off so it will stop that. Not sure if you blank it from both manifolds and block the vac pipe can you lose the whole valve??Originally posted by Baldrick View Postwhat will blocking or removing the egr valve do.
I suppose so.GRAVITY IS A MYTH THE EARTH SUCKS!!!
my mechanic didn't raise any problems with it, the only thing we noticed was the side walls of the cam box were thicker than the original, only time will tell whether it was a good or bad buy but as don't do much more than 1500 miles a year it could be awhile before i know.Originally posted by cupo View Posthow did u go on with head off ebay mate was it ok
I bought a new head and all the new fixings / gaskets etc off e-bay last year, cost £600.00, i also had new drive belt, radiator and water pump fitted, I travel about 500 miles a month and have experienced no problems certainly no loss of water good take off and acceleration, so am well pleased.
