compression
  • compression
    Does anyone know what the compression should be ? I have just run a compression test and it's coming up at 500psi - I'm still trying to solve a poor starting issue and thought it might be lack of compression?
    SS-4 in the manual -
    http://www.spidybot.com/ocqueteau/Na...20Workshop.pdf
    Nev.
      Originally posted by NiftyNev View Post
      Ok so it's not a lack of compression ! It has the symptoms of getting air into the fuel system but I can't find any leaks?
        Have you tried to start it with the fuel cap off?
        SWIFT AND BOLD
