Hello,
I have been scouring the web for information regarding setting the engine idle (tick over) speed for my manual import 1kz-te Surf. There seems to be lots of incomplete posts or broken links relating to setting the idle speed and I am really looking for a definitive answer please if someone can help. Essentially, I have adjusted my engine idle speed down from ~1000RPM to ~750RPM by adjusting the grub screw that sits against the throttle cable pivot on the air intake elbow. This seems to have worked fine and my truck runs really well but I have come across several posts that suggest I should not have adjusted this grub screw and that the ECU sets the engine idle RPM based on readings from the throttle position sensor. Can anyone advise why I shouldn't adjust on the grub screw when everything seems to work so fine? How should I have adjusted my engine idle? TPS repair guides / pictures and explanations are completely lacking, or I can't find anything firm.
Best regards,
-Tom
Best regards,
-Tom
