duel mass converted
  • duel mass converted
    Hi all, I changed my clutch to the traditional type two years ago and annoyingly i think i have an oil leak from my gearbox input shaft dribbling oil on my friction plate which is now giving me intermittent clutch judder. the kit uses a CLK006 260mm. Any one know if i can get just the friction plate as I'd imagine the pressure plate will be still as new??
    If you got the kit from Roughtrax just ask them about the clutch plate only. They should be available as a seperate part.
    Nev.
      I did, but they only sell as a 3 peice kit.
        Have it relined normal cost if around £20
