Bolts to Replace Studs?
  • Bolts to Replace Studs?
    Hi Everyone, I'm in the process of fitting a new cylinder head. I've just about managed to remove all the studs from the inlet & exhaust manifolds from the old to fit to the new, but 3 of them which connect that heater/coolant pipe & bracket Just won't budge! Could I just fit this coolant pipe onto the new head with just bolts? Maybe stainless? Anyone done this?
    Why not just get some new studs ?
      Had a similar problem with mine. Have you tried using a couple of nuts jammed together to unscrew the studs? How here
      https://www.youtube.com/watch?v=8qYKMtb3Jpo
      Usually works ok. You need to jam them together real tight before trying to unscrew the stud.
      Good luck
        I did try to remove the studs by jamming two nuts together really tight but they still wouldn't move. I've virtually ruined the threads! I did that technique with the exhaust & inlet manifold studs but that worked.
        I could get some new studs. Maybe a Toyota dealer? Or company off the internet? Thing is I've got stainless bolts handy ready to fit. What do you think?
          Thanks for your replies, & the YouTube video Jon.
