Hello,
I have a problem with my rear window, and indeed I get it now on no longer, neither the switch or the key (this worked before only to close) When I press the switch to close and the key turn to close I hear how our relay clacks, but in the open position is all quiet.
I guess that just as I read me here that which is my relay in charge of closing the window is broken.
Is that correct?? And if so, which one of you has a relay and a connector for the castle. ??
Thanks and regards
Martin
Thanks and regards
Martin
