I seem to have a quite rough idle on veg - i know veg is thicker etc, but I have a pre heater, so my engine, and fuel lines are 70 degrees hot, so no excuse really, it will run rough as anything if I dont rev the engine, often stalling. Even when the temp gauge is 3/4 up to the middle position (normal running temp)
Would putting a Y peice into the the intake for the fuel and piping the return into this possibly help? It sounds like air is present, but I know it isnt air, I have checked many times with a clear pipe, and tried another IP
I was thinking, it would reduce the amount of 'sucking' the IP wouod have to do in order to get fuel, especially on idle... Or would this cause problems for the pump?
Thanks
Thanks
