Pulling away in 2nd sometimes
  • Pulling away in 2nd sometimes
    Sometimes, when i pull up at lights and dont stop (crawl at say 4 mph) the truck stays in 2nd and its hard to pull away, if a junction is nearby after this then it stays in 2nd even when fully stopped.
    Ive disconnected the batterys and reset the ecu, and I thought it had cured
    It but did it once on a journey just now.
    I cleaned the filter 6 months ago and flushed the fluid. I changed it again last saturday.
    Would it be the 1st gear solenoid? If so how hard is it change? Any writeups? I couldnt find any..
    Many thanks in advance
    Any thoughts?
      Not a clue...
        Try an auto specialist, could something in the box or maybe the convertor
          is te truck lifted? have you checked the position of the shift leaver
          SWIFT AND BOLD
            Still have this problem
            Truck is standard
            Could it be a solenoid?
            It goes into 1st if slelectwd manually with the lever.
