Engine and gearbox mounts
  • Engine and gearbox mounts
    How easy is it to change the engine and the gearbox mounts? I couldnt find any write ups on it, and im sure mine are goosed..
    Any pointers much appreciated
    Thanks in advance
    gearbox are easier, just jack up for support the gearbox, and remove the cross member with the mounts, engine, mmm, a bit more difficult
      Engine mounts are easy too. Support engine on trolley jack, with a plank under the sump. Raise jack to take weight off the mounts. Unbolt, remove, replace. Do one side at a time to prevent lateral movement. Very easy - especially if you have a body lift.
        Sounds easy! I shall order them ! Just wanted to check there was no silly things to be awkward! Cheers
          I forgot to say: support with axel stands on chassis, front wheels off. Access engine mounts through wheel arches - but you knew that.
            Thanks - could have geussed but all advice is greatly received
