Hey,
So after lots of research I have removed the egr system. A multitude of reasons, most will have been covered before I'm sure.
That leads onto the butterflies in the throttle body being next. Not as easy a choice to remove but apparently they will restrict air flow once the egr is removed. This is obviously counter productive. To just blank the pipe is not enough it seems. To complete the job you need to stop the butterflies from causing vacuum in the intake because the egr gasses should be there.
I have nothing current so has anyone got any information on removing these? Your personal experiences?
Are there really any down sides to taking these butterflies out of the intake path? Apparently, apart from providing vacuum for the egr they offer ''some'' runaway protection and a smoother shut down. Can anyone say a 1kzte has suffered runaway ever? I dont know. The internet says the UK 4runners dont have the system at all and neither do many diesels otherwise so it would seem this is maybe just a japanese convention for emissions?
Also once removed what happens to all the vac pipework? No post I have read really gives a definative answer. I kinda think most of it would be redundent but I am not mechanic....I have been searching this subject for hours now. damn toyotadiesel.com/forum and its locked content. I know what I want is in there but i cant access it....
Any constructive comments from like minded modification hobbyists welcomed. Does anyone tinker with their diesel engines like this?
Cheers.
Cheers.
