I have lost power on my 1994 Hilux surf 1kz 3.0 diesel engine. One day I parked and following morning couldn't start. I called the mechanics who said the electronic fuel pump was gone. I replaced with a second hand pump. It started but it is only giving me revs up to 900rpm in idle mode. If I prime the lift pump which seems to be collapsing, the revs only go up to 1000rpm and drops to 900rpm if stop priming. please help:
Lost power and revs 1kz
Did you re-set the ECU?
Try swapping out the correction resistors from your old fuel pump.
http://www.hiluxsurf.co.uk/showthrea...tion+resistors
Lost power and revs
tweak'e . The primer becomes softer immediately after the engine starts I have checked the fuel line, its not showing any signs of damaged pipes.Originally posted by tweak'e View Postwhat do you mean by collapsing?
it sounds like it sucking air in and/or got a fuel blockage.
mine went few weeks back, and wouldn't prime, after running out accidentally. Fuel filter was near empty and wouldn' fill when I checked, depsite fuel in the lines in and out. Filling the fuel filter with ATF and turning it over got it sorted (ta Albannach).Originally posted by tweak'e View Postthats normal.
if it requires more than 2-3 pumps to make it hard then somethings wrong.RZN185 1" lift, 32s - KZN130 2" lift, 32s
