Good evening,
For those of you who haven't seen my thread in the newbie section, I would just like to say hello! I am the happy owner of a 1995 KZN130, which replaced my 300tdi 110.
I have had a read through some of the material on the site and it is all exceptionally useful but I still have a couple of questions which I am hoping someone may be able to shed a little light on.
First things first...
On a recent trip to Guernsey from Leeds, my Surf was pulling like a train until I noticed at one point that it seemed particularly limp. It started loosing momentum and the throttle had no effect, with revs sitting at about 2500. I was crushing at around 75mph, with the temperature gauge sat at about 1/4. I noticed the temperature started to increase to just over 1/2 so I let it hang around 60mph until it cooled and then everything seemed to pull fine again.
When I got to Guernsey, I swapped the radiator cap, changed the fuel & air filters and also checked the vacuum pipe between the boost pressure sensor and the intake manifold. Cleaned the little filter out too so all seemed good.
On the way back from Guernsey the same thing happened again, only this time when sat at 75MPH, I noticed a sudden loss in power as if a boost pipe had failed but with no overheating. Pressing the accelerator again had no effect and the revs were stuck at around 2500. When I stopped, the vacuum hose from the boost pressure sensor had popped off, so I re-connected and the Surf pulled like a train again, even up big hills with absolutely no loss of acceleration.
Now however, the problem seems to have reoccurred. The boost pressure sensor tubing has been replaced, the small filter has been cleaned and there are no obvious issues. The problem is that it just doesn't want to pull up hills as well as it sometimes does. Once the torque converter locks up at about 55-60, it will not accelerate beyond 2500 revs and pull up the hill, meaning I slow down. If I press the throttle to the floor, the gearbox kicks down but then the engine is revving outside its power band and it doesn't pull away.
Is there anything else I can check? Any sensors / vacuum lines that could also cause this issue?
Thanks in advance for any help![Smilie](https://hiluxsurf.co.uk/core/images/smilies/smile.png)
-Tom
-Tom
