Hi folks,
Been a while since i've been on and it looks like nothings changed.
My truck has been running faultlessly till recently when it started running on steam. Took the head off and the cracks were very visible. Having now done the swap with a brand new head, cam, valves etc..., i've almost finished hooking everything up. I've connected enough stuff though to be able to start it as i wanted to make sure it's playing ball.
Did EGR removal as well. Closed up and welded the factory exhaust side plate and made a new one for the inlet. Plugged the solenoid back into the connector just in case it decided to throw a CEL.
Suffice to say it won't start. Checked the timing belt / alignment several times and it looks bang on. All the marks align and the belt hasn't done much mileage so used that.
Checked for fuel and there doesn't seem to be any fuel getting to the injectors. I drove the truck into my garage in the first place so no idea why i don't have any fuel at the moment and i haven't messed about with anything pump wise. I'm going to remove the 4 injector feed pipes from the back of the pump to see if there is any fuel coming out of the pump but i have to say at this time i don't hold much faith.
If the pump is working correctly am i right in saying the fuel will be squirting out the back of the pump from each of the fuel outlets.
If it isn't squirting fuel any ideas as to what might be going wrong. I've checked the fuel filter priming knob and that goes very hard when the filter is full so as far as i can tell there is fuel up to the filter.
Would incorrect timing/pulley alignment stop it pumping fuel? All the electrical connectors are on the pump, i don't think i've left anything out.
Are there any other checks i can do?
Your help is much appreciated because i am well and truly stumped!
