Haven't been outside to check, but pretty sure it goes to the underside of the sensor I've arrowed. Think the bit on the end of the pipe isn't meant to be there.
Correct. The sensor arrowed, is the Turbo Pressure Sensor. The black thing on the end (a filter for one of the VSVs somewhere) does not belong on there. Look at all VSVs and see if one has a missing filter. Should drive better once sensor is connected to this hose.
Thanks chaps, I'll pull the filter off and re-connect the sensor then have a proper look round for any other "loose" lines that look like they should have a filter on.
