the object of my surf like affections has a suspension lift kit fitted is thisa good idea or am i gonna run into a mountain of problems and high bills it also has adjustable gas dampers? eh? wot are these wot do they do and do i need them to improve ride off road capabilites etc? again cheers for da help big jimmy
sorry me again
all depends on how big the lift is?Originally posted by big jimmythe object of my surf like affections has a suspension lift kit fitted is thisa good idea or am i gonna run into a mountain of problems and high bills it also has adjustable gas dampers? eh? wot are these wot do they do and do i need them to improve ride off road capabilites etc? again cheers for da help big jimmy
small then no probs... big then should be alright so long as it's all been done properly.
are the adjustable dampers the 0em ones? of so then swap them for some aftermarket extended ones.nee nar nee nar, i'm a fire engine!
cheers slug man the lift is pretty big looks professional is there any thing i should be looking out for any dodgy linkages or that i should especially b looking for i dunno who makes the dampers and the bloke doesn't seem to either do you think i should change them any way if so is there a specific make i should look at the ones on this truck are adjustable thru a control unit in the cab are these better than manually adjustables thanx for the advice on the insurance too proper useful cheers again
big jimmy
whats up? no .'s or ,'s on the keyboard? thats hard work to read!Originally posted by big jimmycheers slug man the lift is pretty big looks professional is there any thing i should be looking out for any dodgy linkages or that i should especially b looking for i dunno who makes the dampers and the bloke doesn't seem to either do you think i should change them any way if so is there a specific make i should look at the ones on this truck are adjustable thru a control unit in the cab are these better than manually adjustables thanx for the advice on the insurance too proper useful cheers again
big jimmy
Shocks should be matched to the lift, you need to know how much lift to order the right length shocks. You don't need adjustables, Rancho make some but are twice the price of Procomps which will do just fine. If they are Toyota shocks, they will be stock length and will probably be to short to make the most of the extra suspension travel when offroading.
If its all body lift, no suspension changes are made, up to 2" of suspension lift will need little alteration, more than that needs brackets to lower the rear 5 link bars, the front will have dropped diff mounts so the front geometery doesn't change much apart from the steering linkage.
