I know its a FAQ but my 3.0td auto is only doing 17-18mpg driving very carefully! (my old LC80 used to do that)after doing a search I know it should do better what can I do to improve matters? Its on standard size road tyres.
fuel consumption again
You say driving carefully, but are you going fast enough to lock the torque converter? (over 55mph)Originally posted by The Boo Crew View PostI know its a FAQ but my 3.0td auto is only doing 17-18mpg driving very carefully! (my old LC80 used to do that)after doing a search I know it should do better what can I do to improve matters? Its on standard size road tyres.
ECT off?
Only use overdrive if you're going to be driving over 40mph.
What pressure is in the tyres? They needs to be 32psi.
Is the air filter clean?
Are the brakes dragging?
The air filter is clean its mostly round town driving so not much chance of going over 40. Ect is off but overdrive is on. My Colorado changes up at around 1500 rpm round town, weighs nearly a ton more and is full time 4wd at 23mpg overdrive always on. Surf changes up at nearer 2000rpm is this about right? it does however have a ticking noise coming from the engine I don't know if its a bad injector (which might have something to do with it but the emissions are spot on MOT 2 weeks ago) or maybe a tappet?Old enough to know better but then again.....
