How do i access a faulty electric aerial
  • How do i access a faulty electric aerial
    My aerial mast doesnt go down. How do i get to it to remove and repair???
    remove plastic inner wing about 5 10mm bolts from memory, undo nut on aerial on top of wing and should come out then
    My 4x4
    My choice
    Back off
      roughtrax do a black rubber one that fits well if yours is unrepairable. I will say one thing you do need mini hands to fit it tho,there's not a lot of room.
      GRAVITY IS A MYTH THE EARTH SUCKS!!!
        I've had a quick look and it looks like there is a fixing near the bottom of the wing on the liner, cant see how it comes off??
          10mm bolt I think
            Are you sure you need to get under the wing ? Just fixed mine, and all it needed was to loosen the nut on top of the wing holding the aerial.......in fact I followed exactly this advice on the following thread:
            http://www.hiluxsurf.co.uk/showthread.php?t=52051
            Took 2 minutes.
              Just done mine.
              Take inner wheel arch cover...few screws and you will need 10mm spanner to undo one bolt on the bottom of the ariel/unit
              its simple
