ecu for kzn-130 1994 automatic
  • ecu for kzn-130 1994 automatic
    hi guys,
    i hope one of you can help ,i need an ecu 89661-3d100 for an automatic 1994 hilux surf.
    the model is a kd-kzn130w-gkpqt
    engine is 1kz-te 2982 cc
    frame is kzn 130-9057967
    my engine is turning over but i have no power to the glow plug relay (and others apparently) so cannot start.
    toyota have discontinued this part, so i'm hoping i don't have to sell my surf over a little e.c.u..
    thank you
    rory
    Don't know if this is any help,
    Just had exactly the same problem - if the glow plug light didn't flash when ign was turned on it wouldn't start. If glow plug lit it would start no problem.
    Traced fault to no positive supply to ecu, not saying it's the problem but seems similar.
    Just check for power to ecu with ign on, can't remember the pinouts but it's online somewhere.
    Smith & Wesson: the first point & click interface
      In the (hopefully) unlikely even it's the ECU, there are companies to repair them. I had my Fiat done a couple of years back...was £295, but got the job done.
        ecu
        hi you can get hundreds of ecus for surf,s on flea bay
        form as little as £30
        the old git
          good point, I forgot that.
            Not many for a 3.0 though loads for a 2.4.
            Old enough to know better but then again.....
              ecu
              thanks guys, got my e.c.u. repaired 260 quid but back on the road thanks for the suggestions
