Hi all.
Last week i changed all the fluids on my surf and after draining the gearbox fluid, i wasnt happy with just the sump refill of 2.3L that came out, i decided to do a two bucket method today. ( ATF was dark brown, probably original fluid)
As per various researches on how to do a complete flush, i gave it a go.
( Drivers side rad hose=fluid out and Passenger side=fluid in)
I done that only to find out that drivers side hose was sucking the fluid in and passenger side hose was spitting it out
Anyways, after i swapped the hoses again, i only got about 3L of fluid out, but nothing was sucked back in?? I had to refill the fresh fluid trough dipstick.
So thats where i am now.
I haven't driven that car since, just around the block, but there is a slight delay now when first engaging into gear. ?
Is this normal, or am i doing something wrong here?
Thanks in advance
. Anyways, after i swapped the hoses again, i only got about 3L of fluid out, but nothing was sucked back in?? I had to refill the fresh fluid trough dipstick.
Thanks in advance
