Torque setting help please
  • Torque setting help please
    Folks,
    Can any one tell me the correct torque setting for both the Sump Plug and the 19 bolts around the ATF Sump Pan on a 3.0l Gen3 please.
    Thank you and very best regards.
    Phillip
    Quis custodiet ipsos custodes ?
    Settings
    The torque settings for the Sump plug is 35 NM or 25 Ft lbs. The others require 16 NM or 12 Ft lbs. I hope this helps.
      Perfect - cheers.
      So both engine oil and ATF sump plug and nuts are the same.
      I have a poor print of the owners mail but it doesn't really differentiate between the two...
      Appreciate your answer - thank you.
      Best regards.
      Philip
