Sump plug washers ?
  • Sump plug washers ?
    Folks,
    are the engine oil sump plug and ATF sump plug and the washers the same in the 3rd Gen ???
    Cheers + ATVB
    Philip
    Quis custodiet ipsos custodes ?
    No, the engine sump bolt is bigger.
      OK - ta
      Just need to get some replacement washers for the ATF change and leak repair.
      I shall investigate further. Can't just get the same ones I used for the oil change from Rough Trax then.
      Cheers + ATVB
      Philip
        You can buy packets of assorted fibre washers from Halfords or any car accessory place.
          Fibre washers are crap for sump plugs. Use copper or aluminium.
          Nev.
            Nev.
            I use them, they work just fine.
              The fibre one I got from RoughTrax when changing the engine oil seems to be doing a good job !
