Just had MOT, passed with flying colours as always.The Mechanic told me I should look at replacing the fuel pipes that run down the off/side. As they come from the engine bay and turn under the car they are very corroded with flakey paint coming off. They are 2 metal pipes. They are not leaking yet, but it looks imminent.
I can't seem to find anyone selling them.
Roughtrax, Milners etc.
Any one know where I can get a set?
Just had another look at the pipes, they are water pipes that run from the main heater control pipes on the bulkhead to the auxilliary heater for the rear passengers, so not fuel pipes at all
they start off as rubber hoses then metal before connecting to rubber pipes again to enter the floor from underneath.So same question really, where can I get a set?
Also will turning the passenger auxilliary heater to the cold position cut out that section if it does develope a leak on the metal section of the pipe?
I blame the mechanic anyway
