FAO Bushwacker
  • FAO Bushwacker
    Could you be so kind as to tell me what size spanner I require to undo the spill off valve, as it will be worth giving it clean whilst it's off the road.
    Thanks Vince.
    Keep On Truckin!
    32mm.
    I used an adjustable pipe wrench to get it off, it's not stupidly tight.
    p.s. ECU has been collected and will be with you tomorrow.
      32mm.
      I thought so, I did try a pipe wrench but because I'm trying to do it in situ, I couldn't get the jaws around the valve.
      I'm going to buy a 32mm spanner tomorrow and grind it down and chop it in half so it will go in, still got to remove the injector pipes though!
      Thanks for letting me know, hopefully it will arrive in the morning so I can crack on with things through the day.
      Thanks again Vince for all your help.
      Keep On Truckin!
