fuel pump seals
  • fuel pump seals
    hi are the seals for the top of the unit the same as the 2.4 td pump seals
    plus what size is the rpm seal on the top
    Yes.
    No idea.
      cool got a seal kit coming
        Same top and o-ring seal I think.
        Have a couple of 2L-TE pump documents I could send to you if you PM me an email address.
        Nev
          hi the top cover plate seal is the same as the 2.4td one
          but my one was leaking from the sensor on the top
          there was no gasket in the kit that would seal it up
          had to get a seal from motor parts that was about the size of the old one looks like its sealing it but time will tell
            This is the info I have on that o-ring.
            O-RING-096049-0220-22193-5B303-ID 28.2.
            Thought I had cross section of o-ring somewhere so will see if I can find it.
            Nev
              Part number from Toyota should be 22193-5B303
              Nev
                thanks
                will ask if they can get it for me
