On the front face of the alternator adjusting bracket there is a lock nut, lossen it and then you can use the adjusting bolt (the one going through the adjuster block) to tension the belt. Tighten the locknut when your done. Don't overtighten the belt, you can damage the bearings in the alternator.
Alan
