Drive problem
  • #16
    I'd love to know how you manage to get 4.5 litres of fluid out via the drain plug hole.
    I get this also, a 4.55ltr bottle of atf from the local motor factors is just the right size for a change. Does draining hot or cold make much difference?
    Non consternationes.
    • #17
      It burns your fingers.
      If you have lost drive completely, I fear the damage has probably been done. You'll probably find the pump is shagged.
      Pull the hoses off the cooler and put them over a bucket and start the truck, if it only dribbles out when in gear then it's knackered.
      You'll never clean all the contaminated oil out without a complete strip down, and cutting open the torque converter, and it wears the clutch bands away too.
      Just get a good used box and converter.
      • #18
        my old merc had a problem where it would not move up out of 1st. turned out a leak had drained the oil, and burnt the clutches out..... new trans required.... doh!
        If you're gonna be a bear... be a Grizzly.
        • #19
          Just to keep up to date - another 5 litres oil drained and new oil added. In 2WD it will now move at a snails pace but is vlearly shot. I will try disconnecting the oil feed pipes tomorrow just to put a line under it though.
          Question for those that know - How many hours would I expect to be charged for removing and replacing the transmission assuming I was able to source one myself? I'm in North Wales so there are plenty of 4x4 garages but money is tight
