Today, while driving to work, leaving higway, constantly riding @ 60mph, began lowering gears, but somewhat hard.
While reaching the street, it was a question of letting the gas completely, to lower rpm, to be able to shift.
When reached final destination, and stopped, I tried shifting at standstil, but it was impossible.
So I turned off the engine, and tried to shift, and it was flawless, soft as it should be.
With running engine, If I keep it in gear whith clutch engaged, there is no drag.
Clutch action seems untacked, oil level full and no diffrence in pressure feeling.
I have few ideas, like bad clutch plates, synchronization, top bushing..
To make it short, when engine is off, it shifts as it should, soft.
When it's runing, it's impossible to put into gear.
