I'm having problems getting all the air out the braking system. I had to renew all the fixed brake pipes and I now seem to have air still in the rear brakes somewhere.
I've got the trucks rear wheels off the ground and if I run it in gear and press the brake not much happens.
One thing I have noticed is that much less fluid is coming through the bleed nipple on the rear brakes compared with the fronts. Is that normal as I don't have a compensator valve on my 3rd Gen. I'm not sure how it knows how much brake bias to split between front and rear. I wondering if the lack of fluid coming through is a clue as to why the brakes are so sh1t...
Any ideas gratefully received
MikeMike
MikeMike
