i went to change my rear diff oil today when i released the filling nut there was a distinct whooze of air as if it was under pressure. is this normal or do i have a blocked breather.if so is it just a case of removing it and cleaning
axle breather blocked?
I don't think you'll be successful cleaning it, I'd just replace it.
It's a one way valve, by the way, it lets air expand outwards but won't allow it back in. Are you sure it was a positive pressure you felt?Do you know that, with a 50 character limit, it's
If the diff is hot and the breather is blocked, there will be a positive pressure; if it's working properly and the diff is cool (and all the seals are sealing) there will be a negative pressure. If it's failed completely, the pressure will be equalised, so no sook or blow when you remove the plug.Originally posted by sid1 View Postnot sure as to wether positive or negative if its blocked shouldnt it be a positive gush. just remembered i did have a leak of diff fluid onto rear brake drum sometime back which has resolvedLast edited by Albannach; 14 December 2011, 16:26.Do you know that, with a 50 character limit, it's
