few questions but major one concerning overheating :-(( bit of a write up)
What truck is it? The force is still off line, it doesn't like the cold weather.
It's not the head gasket.
Botton? If you mean button, it's the overdrive button.
EDIT - I know it's in the 3.0TD section, but that could be a fluke...Do you know that, with a 50 character limit, it's
A Surf (assuming yours is a 2nd gen) has H - H4 - L4Originally posted by d8moa View Postnext question is 4WD related.... i no hilux trucks have a H-L4-L2 but the surf only has H-L?
Can you please punctuate and use the proper wording when you're asking questions, it makes our lives easier.Do you know that, with a 50 character limit, it's
Did you check the coolant? Surfs don't have overheating issues, they have cracked head issues, which causes it to run out of coolant, then it will overheat.
If its using coolant then you have a problem.
I'm assuming it was dark when you looked at the truck, there is a big button with 4WD stamped on it on the side of the transfer lever! That switches it to 4wd, then pull the lever back for Low range.
Originally posted by d8moa View Postevening all
only had my surf since yesterday and on my road test was ok with no overheating issues (temp was half way etc)
after a run in it tonight the temp gauge crept up slightly more and when i got out the car i heard a 'BOILING' noise
the truck had a new rad and water pump last year so i would like to think there not at fault. i think my next port of call is a new thermostat/rad cap and change the coolant
or am i missing the point that the head gasket has gone haha
next question is 4WD related.... i no hilux trucks have a H-L4-L2 but the surf only has H-L? also there is some kind of botton on the side of the gearshift?
any light on this?
thanks
Damo4x4toys.co.uk - Keeping you on and off the road...
That's not the gearshift. That particular button selects 4wd when in H4.Originally posted by d8moa View PostNot the red button it's the one on the side of the H-L stick.
See what I mean about using the right words when you ask questions?
I didn't even get a mark for my English O Grade and I don't work in a job where I write for a living either; what's your point?Originally posted by d8moa View PostSorry about punctuation but someone who got a F in English at school and does not work in a job writing for a living I find punctuation hard! Least it's
Not txt speak hahaDo you know that, with a 50 character limit, it's
