Hi Folks
Before weekend I cleaned up the battery terminals and it really spins now. It was taking longer to start even then. Tested the glow plugs and they all appeared to be working. Fitted new ones after testing them and number 4 is a bad one to get on to remove. Anyway no change it just cranks and won't start! A test lamp on the wire to the plugs lit up when the key is turned so Can I assume something else is failing. The big fuse look good, the relay next to the starter relay how can I tell if that is playing up and is it just a push fit on and off?
I hope someone can spare a few moments to answer.
Thanks J.
Thanks J.
