Just a quick one back window washer jet not working,the washer motor runs but no water out of jet which i have cleaned,and i get a small amount of water in the rear of the boot roof lining is that where the pipe runs through? cheers.
Back window washer
Rear wash wipe
Dave,had just this problem on mine six months ago.If you remove the trim that fits around the rear wiper motor,locate the plastic/rubber tube the water flows through,approximately six inches from the washer jet end there is a one way valve,a bit of "nylon" tube with a ball bearing and a spring in it.The ball sticks and wont allow water through,fit a new one,cheap from local factors,push it with a stick to release it,or just do away with the one way valve and fit a new piece of tube,Proper job
