Not sure why this is happening? if i drive at 2500rpm every so often i get a dip in power then it picks up again its a gen2 3l auto.It drives fine and revs fine just drops power at a constant 2500rpm. I have checked all the pipes around the turbo for splits/leaks etc and all is fine.There is no smoke to be honest i`m abit lost.
Dip in power?
A you getting the engine check light on as well which goes off when you throttle back... I am for weeks now and still no closer to finding the fault....Originally posted by marcdtr View PostNot sure why this is happening? if i drive at 2500rpm every so often i get a dip in power then it picks up again its a gen2 3l auto.It drives fine and revs fine just drops power at a constant 2500rpm. I have checked all the pipes around the turbo for splits/leaks etc and all is fine.There is no smoke to be honest i`m abit lost.
