I've seen a fair few posts about the general hit and miss state of affairs with the fuel gauges, but not many members have mentioned their gauge getting stuck on empty; any ideas if this is likely to be the float jammed down? A female friend's truck, and she's getting panicky about running out on a motorway
fuel gauge stuck on empty...
Ok, mate- will check the connection today, I guessed that suggesting filling the tank wasn't meant in a tongue in cheek way, but she has done that several times,Originally posted by BUSHWHACKER View PostCheck the electrical connection on top of the tank, the terminals can corrode quite badly. You can access it via the removable inspection plate under the rear seat.
Or, fill the tank (expensive I know) to see if the float frees itself off the bottom.
