I did do a search but what I found with the info didnt make sense,ie
looking at the pump, the order in which the pipes are connected are
3 1
4 2
is this definately correct?,so cylinder pipe no.1 goes to top right thread
pipe no.2 bottom right
pipe no.3 top left
pipe no. 4 bottom left
I marked the top of the pipes before removal and if fitting them in the above order
no. 1 pipe for example is too long for top right? and so on,
I find they fit better as no.1 pipe bottom right (block side)
no.2 pipe bottom left (wing side)
no.3 pipe top right (block)
no.4 pipe top left (wing)
Have not torqed them up yet just wanted to make sure 100% and info appreciated!
3 1
4 2
pipe no.3 top left
