Hello - I bought the wife a 3.0L Surf in the bad weather earlier this year.
The surf has 120K on it or thereabouts. Its an N reg. I paid £2300
It's been great until two weeks ago. She was driving up a hill and noticed the engine light came on and the temp gauge was in the red. She tried to go a bit further to pull off the dual carriageway and the car died. It would not start again and had to be towed to the garage. Here is what I have been told by the mechanic:-
There is no coolant in the radiator system.
There is some piston slap (but not major)
The head is warped
He cannot see anything wrong with the engine elsewhere.
He filled the cooling system up and left it overnight - in the morning it was all gone.
The head has gone for a crack test and possible skim
Does anyone have any idea what may have happened to it and how much it will cost to repair and whether its worth doing?
I thought it was the 2.4 that was supposed to overheat and crack the head?
The mechanic is concerned that the bottom end bearings may be screwed as a result of the intense heat.
I await the results of the crack test but am unsure (due to my limited knowledge) if a cracked head or failed gasket is the cause or symptom of the coolant loss and overheat.
Also if the engine has overheated this much is it knackered and should I look to trade it in or otherwise get rid of it?
The head is warped
) You can overheat a 2nd Gen truck quite easily, there isn't much spare capacity when worked hard, but it won't kill it instantly like a 2.4.
Nah you don't need the right antifreeze for the internals like pumps, metal pipes, radiators and rubber pipes its just a lump of iron or thats what I have been told on here, any body wondered why so many problems rear there heads using any old antifreeze but then it might be just toyota hype.
