3lt td wont run once started stoped?
  • 3lt td wont run once started stoped?
    rebuilt 3lt td new pistons ,rings ,shells ,put back in primed started easy !!
    but when started disengaged it stops
    any ideas please!!!!!
    Read this back out loud, if you can make any sense from it your dyslexic. H
      Not put in the best way sorry
      thinks it the crank sensor want help if poss
        I'd love to help, but I can't make any sense of this.
        '96 Toyota Hilux Surf SSR-G - RIP
          Engine turns over fires up then when let go of key
          It stops
          Need help I think it's crank sensor but need second opion or third
          Need truck running for sunday
            Have you tried the diagnostic codes?
            Otherwise something could be wired wrong so that ECU isn't getting 12v with key in ign position.
              I'll check into the codes not sure how to do that yet but will do a search on here thanks for help
                Could be a fuel pump sensor.
                Or bad earth, check the one at back of engine just below block deck.
                Alan
                  Your a life saver thanks I love this forum
                  It was the earth on the back of the block
                  Nice one thanks it started straight away once connected
