every now and again the starter motor sounds to over run,just a few secs,been advised to take it out and oil it.does this sound ok and has anyone else had this.thanks
starter moter
Originally posted by s-dawson View PostHi
did mine the other week got the kit from RT and it took 30 mins from start to finish.
well worth it and such a difference
You did well removing the starter, fitting the new kit, replacing the starter in 30 mins.Alan
If you are desperate
If you are desperate and the starter wont connect AND you have some 15mm copper pipe.
Just flatten it, file it, drill it and bend it, you can make your own kit.
Works a treat BUT a kit is much better if you can wait for one to arrive.
Mind you once you have done this you wont feel like taking it out a second time to put a kit in.
Mine is still in 9 months later still works though.
John
