Hi I'd like to clean out the fuel pump if I have one, where do I find it and any tips?
Where do I find the Fuel pump?
If you want to clean the fuel pump then you will need to renew the cam belt etc aswell because it all has to come off if you want to take the pump out.
The best way to do it and thats fit a new fuel filter and fill it to the top with either redex or ATF and then drive the truck like you stole it for a few miles
The fuel pump is located n/s front of the block where the 4 injector pipes fit onto.
There is no other fuel pumps on a surfhttps://www.facebook.com/groups/henpals/
