hi just a heads up, changed my cam belt pulley at the weekend and the bush in the cam belt pulley housing was the wrong size, new part had a 17mm bush but the pivot pin is 16mm. got the part from milners so its worth checking before you change it, wasn't impressed when i found out when my cam belt was off
