Is it possible to 'fix' a leaking injector pump without replacing the top seal?
3.0L Fuel Pump seals
Hi Albannach,Originally posted by Albannach View PostIs it possible to 'fix' a leaking injector pump without replacing the top seal?
I had a leaking pump during the cold spell earlier
this year, it would leak on start up but stop, if I stopped
and re started the engine after about 2 mins.
I put 1/2 ltr of ATF plus 250ml of Redex diesel treatment
in 1/2 a tank and it stopped in 2 days, it's not dripped a
drop since.
Gman.If it aint broke, keep goin' till it is.
I was just wondering if there was a quick fix for them, something I could have done at work tonight.Originally posted by TonyN View Postjust changing the top seal is a doddle on EFI trucks, its nothing to worry about.
My problem now is that I can't find anyone that sells them.Do you know that, with a 50 character limit, it's
Hey Albannach, if you can get me the numbers from the side of the seal I should be able to source one. (obviously the problem then is that you have the pump in bits if I can't get it to you for a few days or at all).Originally posted by Albannach View PostI was just wondering if there was a quick fix for them, something I could have done at work tonight.
Let me know,
Ray.I've got a plan and it's as hot as my pants!
I think that's where mine is leaking from, but I'll change the top seal too. Maybe just bite the bullet and buy them from Toyota?Originally posted by Thriftymy leak turned out to be the o ring on the sensor the one with the 32 mm? nut. i didnt have a spare so i wrpped it with ptfe tape and its been fine since. i did however change the top seal on the lid the rectangular one it was easy peasy. hope this helps
Thanks for the offer Ray, I'll let you know. As you say, the problem is having the truck laid up for too long.Originally posted by lord_flashart View PostHey Albannach, if you can get me the numbers from the side of the seal I should be able to source one. (obviously the problem then is that you have the pump in bits if I can't get it to you for a few days or at all).Do you know that, with a 50 character limit, it's
The lid seal is the wriggly shaped one in this kit, not sure you can buy it individually from Toyota.
http://www.roughtrax4x4.com/?doc=16&cid=610&vid=1242
I saw that one, but it only says 2.4 and 2.8. Will it do a free leeter too?Originally posted by TonyN View PostThe lid seal is the wriggly shaped one in this kit, not sure you can buy it individually from Toyota.
yeah, thay are all the same pump bodies, i'd guess they are just set up differently inside for different capacity engines.
Note, it dosn't actually include the o-ring for the PRM sensor plug, but they are only an o-ring and easy to find. but the lid cover is the important one.4x4toys.co.uk - Keeping you on and off the road...
