Just about to refit my refurbished injectors which is the last part of the engine rebuild. Is there supposed to be a washer between the little cap inside the head and the injector? Dont want to have to take them out again. Thanks for any help.
Refitting injectors???
If your talking about where the bottom of the injector mates against the cylinder head then yes there is supposed to be a small crush washer in there. When I had my injectors rebuilt a year ago the injectors came with new crush washers as well as the new aluminum looking washers that go on the fuel return lines.
On the new head I fitted, the kit came with the steel nozzle cups (once fitted are permanent) and new crush washers but no fuel return washers, so maybe fine just to use your old ones. I did and it runs fine.Alan
ah, yeah, if you bought a built head you need to send them back, or people will get annoyed.
