Hi guy's
Following my recent IP, starter solenoid and split CV boot problems my rear window has decided not to work from the switch inside the car.
It works fine from the key switch on the tail gate.
I did try a replacement ECU when my IP packed up just in case but cant see that I dislodged anything near there.
Is there a fuse anywhere that just controls the inside switch, also back in winter my rear screen heater and rear washers packed up, do you think there may be a connection (no pun intended)
Regards John
Regards John
