I am just purchasing a 3.0 SSRX. It is described as a 1994 model and is on a L plate. It has the vin number KZN130 -9033750. Can I find out from this the date of manufacture, engine type etc ? Many thanks
Vin Number
quickest way to check year of manufacture on any Jap import is to check for a tag on the seat belt, usually where end of lap portion attaches to floor. This will have the date of manufacture on it (month and year are show if I remember correctly)Originally posted by Andrew99I am just purchasing a 3.0 SSRX. It is described as a 1994 model and is on a L plate. It has the vin number KZN130 -9033750. Can I find out from this the date of manufacture, engine type etc ? Many thanksMaurice
Hello my surf is a 95 model on the log book, but came out as Dec 94,Originally posted by TallymanUseful link, thanks. Put mine in, stirred, and came out as Dec 93, so it's probably technically a 94 model as it probably wasn't first sold until early 94.
Cheers Kevin95, SSRX, TD, AUTO,
The form comes up with a different answer to the table. Or more likely I am not using it properly!
http://www.toyota.mnc.ru/framno/KZN130.htmlIf life's an uphill struggle then downhill from now on can't be that bad?!
