Checked my brakes the other day, and found 'grease' in the hub and on the back plate. Is this the 'dreaded rear seal disease'? (Daft question I suppose.)
If so, must you change the lot, as in inner/outer seal and bearing? I suppose if there is grease in there, the outer seal must have failed?
Any (usefull) thoughts appreciated. Are Rough Trax bearing kits as good as Toyota stuff, price of both etc.
