My rear brake bias valve that sits under the truck and has a rod connecting it to the axle has seized
How easy is it to change?
do i need to change it or is it likly to be servicable ie strip and clean?or is it a new part?
it looks like the valve part unscrews from the bottom of the main body of the valve? thus very easy to change and then just bleed?do i need to bleed to the brakes or just the valve?
cheers rob
cheers rob
