Hi ya,have a n plate surf 3.0td,pressurizing cooling system big time,hasn't got hot at all,laid her up straight away. Just wondering on the likelyhood of a cracked head and if so can you normally see it visibly ? or is it crack test to find out..And has anyone has good results with pattern heads,seen quite alot assembled on ebay for a good price.
Thanks.
Thanks.
). It is not always the case.
